Lines on Screen Phillips 36PW
Discussion in 'General TV Discussions Forum' started by wrighty76, Mar 3, 2005.
  1. wrighty76
    wrighty76
    Hello
    Can anyone help me? I have a small problem with my Phillips 36PW and it is starting to bug me. I think it may be interference or something, I'm not sure...just hoping the set isn't damaged.
    I'm having trouble with the picture - on the left hand side of the screen there are three vertical lines. They are like ghost lines - hardly noticeable, but they still bug me. They aren't there all the time, but seem to be there quite often. It happens when I am watching DVDs, TV, or on the PS2 and is much more noticeable when the screen is showing something black. I can see no trace of the lines when the blue screen or teletext is on.
    I have a freeview digital box connected to the tv via a scart, and I use the side RGB conenctions for the DVD. The digital box is also connected to my video via scart and the video is plugged in to the normal aerial on the tv set.
    Can anyone help me eliminate the lines? Could it be something to do with the second scart socket? I read somewhere that it can only be used for certain things...maybe I have the digibox connected to the wrong scart?
    Thanks in advance
  2. Pug72
    Pug72
    May 10, 2003
    2,087
    Hereford
    +311
    I have the exact same prob on my Thomson tv.
    Would love to know what causes and fixes it.
  3. wrighty76
    wrighty76
    Hmm...seems to suggest that it isn't a fault with the set then...myabe it is some sort of signal interference. It certainly looks like 'ghosting' in appearance.
    Surely someone out there knows about this?
  4. scooby do
    scooby do
    Dec 11, 2002
    1,984
    48
    +83
    Do a search for 9607 and you will find a lot of discussion about bars/ ghosts. There are some jpegs of the lines that may be familiar to you Note these lines vary from set to set and also can really stand out during panning shots football.
