Line input to iPhone mic input
Discussion in 'iPhone Forum' started by danc81, Jan 7, 2012.
Tags:
  1. danc81
    danc81
    Jan 7, 2012
    3
    I need some advise on getting a line in input source into the mic input of an iPhone. I thought it would be as easy as purchasing a length of cable and 2 plugs but I've been told it's not that straight forward due to the impedance of the iPhone mic input.
    My knowledge of hardware and audio equipment is very limited but I need the input for an iPhone app that I'm working on which will record the input from the mix socket.
    Is this possible? What would I need to do it?
    Thanks,
    Dan
  2. DanParker
    DanParker
    Jun 24, 2010
    502
    +77
    Try iRig. Think there is different versions available but I'm sure it should do what you want.
