Limited width for table-top LCD: help needed with choosing product
Discussion in 'LCD & LED LCD TVs' started by Nimrod169, May 24, 2005.
  1. Nimrod169
    Nimrod169
    May 24, 2005
    I couldn't find another thread with the same topic but sorry if I am repeating one.
    I am upgrading from a 4:3 TV and limited space would appear to determine the choice of replacement. (It's all to do with the position of windows, doors and furniture). The footprint of a 16:9 CRT TV is too big so I'm looking at a 23" LCD at just over 600mm width - can't go much wider. While I am not a purist, I don't want to watch/listen to really poor quality. LCD will be used with Pioneer DVD player and Thomson 2-tuner combi HDD recorder and Freeview.
    Two products seem suitable: JVC LT23C50BJ or Sony KLVL23M1.
    And this is where I need help. Are there other possibilities, other suitable products at reasonable quality, vfm?
    Many thanks.
