Limit on no of files for a DVD R ?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by RecordablDVDfan, Nov 11, 2003.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,900
    68
    +49
    I have converted almost 600 real video clips to VCD format this amounts to around a total of 1.8GB whch I want to put on a DVD disk. Ulead DVD movie factory and workshop throw up a msg words to the effect 'no more files can be added' though WINONCD 6.0 does'nt give any message just the the total size of the disk is over 11GB and proceeds to convert every file again for some reason ??!!
    So is there a file limit as with a CDR (99 files) and if not can someone suggest a good DVD authoring / creation prog to use ?
