Limit DVD9900SE 5.1 Out vs. Opt. Dig. Out
Discussion in 'Blu-ray & DVD Players & Recorders' started by Anomar, Mar 23, 2003.
  1. Anomar
    Anomar
    Mar 23, 2003
    12
    London UK, SE16
    Hi All,
    I'm somewhat of a novice at all this A/V stuff, so can someone please help me with a query:
    I have a Limit DVD9900SE and a Marantz SR7300. The Limit has 5.1 outputs, but the Marantz is compatible for 7.1.
    If I connect the 5.1 from the DVD to the Marantz, the Marantz manual tells me that this connection overrides any internal decoding -- i.e. only the 5.1 will be available.
    My question concerns Optical Digital output on the DVD. Since the Limit also has digi output, should I use that connection into the Marantz, and allow the Marantz to handle the decoding? Since it's a opt. digital output, won't that carry a good clean signal anyway?
    Any advice is greatly appreciated.
    Regards,
    John
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Let the Marantz handle the decoding by using a digital (optical or coaxial) connection, it'll have better decoding than the Limit. ;)
