Limit 900se Prog scan help needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by BIONIC MAN, Jul 7, 2005.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    :lease: Need some Help
    I have the Limit DvD900se been using on an non Prog Scan Tv via component all worked ok :smashin: .
    Then connected the Tevion 32" via scart lead and changed player to output Prog Scan :) all worked ok but was not happy with the Tv so took back for a refund .
    What I need to know the player will not now display picture on my non Prog Scan Tv :confused: WHY . Do I need to change back the player to Interlaced mode BUT CAN NOT :mad: change back
    I can not use my Limit 900se now
    :hiya:
  2. Elephant Man
    Elephant Man
    Jul 15, 2000
    332
    England
    +7
    did u press the P/I button on the remote?
  3. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Yeah I did with no luck :thumbsdow , it worked fine before I connected tlo the Tevion 32" lcd Tv
    What has happened to the player :rolleyes:
    :D
  4. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    This may sound daft, but you need to press it twice for it to change from one mode to the other. The fist press brings up the current state and the second press changes it.
  5. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Thanks m8
    Will give that a try later :smashin: , I hope this works
  6. Stathis
    Stathis
    You need to press it twice for it to change from one mode to the other BUT IN STOP MODE. If the disk plays, nothing will happen ;)
  7. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Thanks Guys :smashin:
    All sorted now :D , Picture back
