Limit 900SE not multi-region
Discussion in 'Blu-ray & DVD Players & Recorders' started by Stuart.Ainslie, May 12, 2005.
  1. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    127
    16
    Little Clacton, Essex
    Just received my Limit 900SE from Play. Advertised as multi-region and Cyrus tuned.
    Does not play any multi-region DVD's and has no Cyrus marking or paperwork - Not too impressed at present.
    Spoke to a firend who also ordered one, same deal for him too !
    Anything I should know before hassling Play ? :lease:
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    You need to run the handset hack for it, which I got from the the DVD player handset hacks forum. Run that and all your disks should play.
  3. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,go back in this forum (dvd player's)search for limit900se or limit800se(big thread under this which cover's as much about 900 as 800)you will find the hack and learn more.My player is badged cyrus,had it a couple of month's as long as the inside component's are as per what Cyrus prob spec'ed cannot see any problem.Only minor prob's i have(which i think are common)are every time you switch it on,if you are wanting output in RGB you have to set it again each time.Other prob transport system noisy even when idling.
    BOB
  4. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    127
    16
    Thanks for the advice, I'll try the hack tonight...
    Was a bit peed off, as it was advertised as multi-region out of the box and expected it to work.
    Am well impressed with the picture quality over component and build quality seems good. Do agree that the transit is a bit noisy though....
    Stuart
  5. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    Yeah I think Limit were advertising them like this too when I got mine, but the crack only takes 30 seconds and it works a treat.
    It's a fantastic player for the money.
  6. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,reading thread's on here people with projector's etc think it's good using component,picture good via RGB on my Sony 32inch CRT.CD sound and DVD-A sound also Excellent(reading on here supposedly the Zoran video chip in it is the same as what Arcam use,if not the latest chip model).Also another minor prob,you cannot switch it to off/on or standby using remote(that's when you notice transport noise most).But for price a bargain,it don't do SACD,but maybe with DualDisc coming out we might get a few more title's to choose from(hope what come's out have proper DVD-A on them),tried the free DualDisc(Hi-Fi Choice Mag out now)and played DVD side and sounded OK
    BOB
  7. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    i've just checked my 900se from play.com and it isn't multi-region either, the bloody swines :mad:
  8. osmyth
    osmyth
    Nov 10, 2002
    281
    16
    York
    Just received mine from Play this morning.
    Box and player said 900 rather than 900SE and there wasn't a Cyrus badge. Thought there may be a non-tweaked version called just 900, so rang Limit just now. Spoke to Nick (assume the same Nick who has been on here), he said that all 900's have been tuned by Cyrus and was surprised there wasn't a badge (he's going to send me one!).
    I also mentioned the MR thing, and he said that you need to do the remote hack. He's emailed it to me:
    1. Open the disc tray
    2. On the remote, press the 10+ button, quickly followed by 5 3 6 7 5 1
    3. Choose the region code by pressing 1 for R1, 2 for R2, etc. or 9 for all regions.
    The OSD will say A1, A2, A9, etc.
    4. To enable/disable VCD playback, press 8. The OSD will say C0D0 for VCD off,
    and C1D1 for VCD on. The 8 button toggles between on and off.
    I'll reply suggesting that he contacts Play to get them to remove the MR bit if all their 900's aren't built with MR.
    If all 900's are SE then why didn't they just call it 900 as there is no mention of 900SE anywhere!
    Be interesting if any 900SE owners have SE mentioned anywhere on the player/box/docs.
    Limit - 0845 226 1619, [email protected].
    Owen.
  9. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,got my limit from Play.com,had it a couple of month's or so.It has the Cyrus badge,on box it only say's DVDA900 (DVD1901).On manual say's DVDA900.
    BOB
  10. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    my 900se has a cyrus badge on the front, but didn't come with the autheticity certificate tat came with my 800se that i bought directly from the limit website.
    osmyth - if you speak to nick again ask him, how come play are selling these machines at such low prices yet their own website still lists full price?
    thanks
  11. osmyth
    osmyth
    Nov 10, 2002
    281
    16
    York
    Just been playing a few disks.
    The picture is a lot better than my Panasonic e30 dvd-recorder as that seemed a bit dull whereas the Limit is a lot more vivid.
    Waiting on a component cable to be delivered to try Progressive, compared to the Pana pe30 inbuilt de-interlacer, hopefully that will improve the pic some more.
    Only downside I can see so far is the mechanism/laser/transport whatever you might call it. It is noticeable when the film starts (Pana e30 wasn't really noticeable), however it seems to progressively get quieter the further through a film you go. Same for a CD, if you skip tracks, the tone of the mechanism reduces.
    Anyone else the same?
    Owen.
  12. Chesterwood
    Chesterwood
    Play.com are still advertising Limit DVDA900SE's but can only supply Limit DVDA900's (at least from last week when I tried to order mine - and got a 900 instead of a 900SE).
    My email to [email protected] about the difference between the 900 and 900SE has just been answered:
    Thanks for your message. The SE versions of the DVD800 and DVDA900 are
    specially tuned by Cyrus. The old versions are no longer produced.
    Best regards,
    Nick
    Limit UK
  13. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Belfast, Northern Ireland
    Yeah I'm only after to checking mine (I bought it 2 weeks ago) and it's a DVDA900 and not DVDA900SE!!! Maybe the lack of SE's is the reason the players are now down to £49.99 on Play.com!!! This has really peeved me off, not only did I not get an SE but the price has been cut by £30 in 2 weeks!!!!
  14. nhalliday
    nhalliday
    Sep 24, 2002
    79
    Just to clarify the situation:
    All Limit DVD players currently sold by Play are definitely the SE (Cyrus-tuned) versions. When we originally produced these models, we were also making non-SE versions, so to differentiate the stock (more for our own use than anything else), we put a "Tuned by Cyrus" sticker on the box. Since we no longer produce the non-SE versions, there's no chance of any mix-ups in the warehouse, so later production uses the standard box without stickers.
    We also took the decision to stop printing the certificates in order to save on cost. If anyone really wants a certificate, please PM me and I'll send one out, as I've still got a few in the office.
    It also appears from posts here that a small quantity of stock had the Cyrus badges missed off during the production process. These should definitely be there, and if you need one, again, please PM me and I'll organise it. Just to reiterate, all stock sold by Play is definitely SE-standard.
    Play are able to sell the players at such a low price due to their enormous buying power, together with a general reduction in production costs of these players since their release a couple of years ago. Due to them being an internet-only retailer, they benefit from reduced overheads, and I believe that there also certain fiscal advantages in them being based in Jersey.
    I hope that this clears up any misunderstandings.
    Cheers,
    Nick
  15. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    I take it PM means Personal Message? I've sent you one requesting a certificate an badge, just wondering if you got it?
  16. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    Now it's clarified that these are SE models for £50 it's a steal. I'm thinking of getting one for the Cyrus CD side alone to replace the portable CD going through the stereo upstairs, and it'll double as a DVD player!
  17. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Good idea, it definitely is a fantastic bargain!
  18. osmyth
    osmyth
    Nov 10, 2002
    281
    16
    York
    The only thing I would say against it is the noisy mechanism for the 1st part of a disk. The lack of a standby button on the remote may also put people off. Aside from that it's very good, and for £50 it's a bargain.
    Owen.
  19. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    Just ordered one.
  20. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    127
    16
    Big thanks to Nick from Limit...
    Sent PM over the weekend about the lack of a Cyrus badge - badge turned up in the post today.
    A rather nice DVD/CD player and good customer service too....
  21. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    I haven't had a real chance to get it up and running and comparing it to my old Tosh 220 but on first impressions it's pretty good, not as noisy as I feared, but no Cyrus badge. Sent PM to get one though.
  22. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Anyone know how long delivery usually takes from Play for these type of items?
  23. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    Ordered Monday
    Despatched Tuesday
    Arrived yesterday but I was out.
    Re-delivered 9.00 this morning.
    Play email said 3-5 days after despatch, I live in the south east.
    Nick has already sent a PM and my badge is being sent.
    How can you beat that!
  24. Spikeout
    Spikeout
    Jun 13, 2005
    3
    Hey guys I am gonna buy the Limit 900SE from play and have a few questions. The way it says it comes with no cables I take it that just means I need to buy a scart and if so is the Thor scart at £17.99 worth getting and is it that much of an improvement over a standard scart. Secondly this will come to near £70 and I was looking at the Sony DVP-LS755 at £80 would that be worth getting instead?
    Thanks in advance
  25. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Yes you'll have to buy your own scart leads, I bought the IXOS XHT611 scart lead with my Limit 900SE. Don't know much about the Sony DVP-LS755 but I can tell you now that the Limit 900SE is a steal at £49.99!! Go for it.
  26. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    Well after looking at mine for the past few days I'm amazed. With component it beats what I thought was my unbeatable Tosh 220. It doesn't appear as detailed as my 220, yet the picture seems more natural and relaxing to look at.
    And Nick, if your reading this, thanks very much, my little Cryus sticker arrived today.
  27. Achy
    Achy
    Oct 23, 2002
    297
    28
    +30
    Does the 900SE play DivX 's ?
  28. Wilf
    Wilf
    Jan 11, 2001
    375
    Staffordshire
    +6
    Pakehurst, unfortunately no DivX support.
    Have to reiterate that this is an absolute no-brainer for £50
  29. thesnowman
    thesnowman
    Nov 14, 2003
    271
    +8
    can the Limit DVDA900SE handle dvd-rw disc?
  30. Nabs
    Nabs
    Feb 5, 2004
    762
    +10
    Have a pioneer 656A at the present time however the laser seems to be wearing as the player gets stuck on dvds that previously played ok. Has happened to a previous player a few years ago.
    Was looking at this review - what is the limit's picture quality like? and how good is it playing SVCD DVDR -/+ , DVDRW -/+ and DL? Would I be better off just getting anothe pioneer eg 585 or something.... The idea that cyrus has had a play sounds interesting,
