Like Your DVE Results
Discussion in 'Plasma TVs Forum' started by Anthall, Jan 6, 2005.
  1. Anthall
    Anthall
    Oct 27, 2004
    220
    Kettering
    +4
    I finally set up my viera 42" with the DVE disc (Pal). Found that all
    the settings, i.e. contrast, brightness etc have ended up at just
    past the half way mark, in cinema mode.
    What im upset about is that im not really happy with the end result.
    I was instantly tempted to tweak it to how i like it best. As if i
    know best or something.
    (Maybe i got use to the panel with low brightness setting etc!)
    I guess you should have it set up to how you prefer? but i was just a
    little annoyed. I think i was expecting a definitive answer to how the
    screen looks best.
    What i want to know is, has anyone else had the same experience or
    do you go along with the DVE settings??
    I was impressed with the audio sections of the Disc. Probably worth buying
    for those alone.
    Look forward to your views!!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    DVE is just a more scientific way to tweeak (ambientlight makes a big difference) Calibrate in watching conditons ie curtains closed lights off or midday curtains open all lights on....... (that bit is explained on the disc...)
  3. hao
    hao
    Used DVE on my CRT, whilst waiting for my Viera, didn't like the results so switched back to eyeball. Haven't found the need to use it on my two week old Viera as the PQ looks great on cinema with settings about half way and colour set to cool. It seems to get better with time.
