Hi all,
I have several points in my house where there’s 2 gangs and one controls the ceiling LED spot lights and the other controls LED strip lighting.
WIth the GeN 1 switches I would put a relay on the LED strip lights and have to use two separate switches - a dimmer and a remote switch.
With the Gen 2 smart switches as long as one gang has a dimmer connected all 4 gang switches can get their power from here, and I can pair one gang using the app to the relay.
I have no idea why they didn’t just build switching into these switches since the power issue is now resolved.
Anyway I was wondering if anyone has tried connecting a non switchable load to a second gang on the gen 2 switches? What happens?
can soft start be switched off at all? And are they are settings that can control the dim on/off level or manual calibration that might help this work?
I have asked Lightwave to see if they can make a firmware change to enable this but got the usual ‘your feedback is appreciated’ response.
Its the one killer feature that would actually make Lightwave switches do what all other smart switches can’t - no neutral wire, non dimmable switching, without batteries (with the caveat one gang has to be on a dimmable circuit).
