lights blown, fuse box help
Discussion in 'General Chat' started by dj_padd, Mar 11, 2013.
  1. dj_padd
    dj_padd
    Dec 27, 2008
    1,516
    Mid Wales
    +255
    Turned the hall way light on this morning and it blew the main fuse and the fuse the lights are on. Switched them back on but none of the lights in the house will come on.
    Any ideas?
  2. dj_padd
    dj_padd
    Dec 27, 2008
    1,516
    Mid Wales
    +255
    The timer that controls the heating and hot water has stopped working. It's stuck on the time when the lights blew this morning.
  3. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,127
    +7,283
    I take that when you say fuses you mean an RCD trip? In which case maybe you've missed one that still needs to be reset. One all I've seen up is on rather than down.
    Have you removed the blown bulb?
  4. blue max
    blue max
    Apr 12, 2006
    12,936
    London
    +4,307
    Circuits these days are split usually. IE you have two banks of switches. You then have a master switch on the two banks. Individual switches can trip, but take the master switch with it.
    Sounds like that has happened.
  5. dj_padd
    dj_padd
    Dec 27, 2008
    1,516
    Mid Wales
    +255
    The white box I have switched back/reset but the old looking black one I have never seen before.
    The bulb that blew has been removed.
  6. blue max
    blue max
    Apr 12, 2006
    12,936
    London
    +4,307
    On the black one, the white one on the left is a circuit breaker, the rest of wired fuses. Not sure why you have two - is the new one an extension?
    Pull the wired ones out and check the wires are intact. A bulb blowing can often cause a fuse to break.
    Turn off the main black switch first though.
  7. dj_padd
    dj_padd
    Dec 27, 2008
    1,516
    Mid Wales
    +255
    Thanks, Only been living in this house for about 5 weeks and never seen one of those black ones before
  8. blue max
    blue max
    Apr 12, 2006
    12,936
    London
    +4,307
    Be aware that you may need some fuse wire to replace the broken one - or replace with a circuit breaker - make sure it is the same wattage as the fuse. If replacing with a circuit breaker, take the old one with you to get the same type. Make sure you don't turn off freezers though.
  9. IronGiant
    IronGiant
    Jun 7, 2003
    65,884
    +45,883
    If it's wired up correctly it should be:
    5 amp, White: Lighting / small plug circuits
    15 amp, Blue: Immersion/storage heaters
    30 amp, Red: Ring circuits (sockets), cookers, showers, radial circuits
    If you pull them out and there are cartridge fuses, the following applies:
    5 amp,White: Lighting / small plug circuits
    20 amp, Yellow: Smaller radial circuits / water heaters
    45 amp, Green: Cookers/showers
  10. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,127
    +7,283
    As Blue Max said, the black box is an old style physical fuse box which would normally be replaced by the white consumer unit, so I don't know why you have both either. The physical fuse blocks can be replaced with RCD breakers which is what has happened with the one on the left. That should be in the up position, same as the switches on the white box.
    If that is up then turn off the switch on the black box (in this case off is up!) & pull the blocks out one at a time. You should be able to see the fuse wire running between the terminals. It will be obvious if it's broken.
  11. campy mccamper
    campy mccamper
    Nov 30, 2009
    3,696
    +549
    If you locate the lighting circuit on your consumer unit, try switching the mcb on and off a few times. It can be a common occurrence that the mechanical switch can stick if they are not tested regularly.
