Lightning Strike / Surge Protection / Power Conditioning...
Discussion in 'Cables & Switches' started by Neil F Holland, Oct 24, 2005.
  1. Neil F Holland
    Neil F Holland
    Oct 29, 2004
    223
    19
    Bromley
    Folks,
    Am about to procure first home cinema set-up and am looking to understand what if any of the above protection I should consider...
    a) I can get a surge protected extension lead for less that £20...
    b) Power conditioners (presumably including surge and brown-out protection) comes in at £120 ish...
    I'm looking at a Philips 963 SDI DVD player, an Onkyo 653 A/V Receiver, a Topfield Freeview Box, Lumagen VisionHDP Scaler.
    Should I go for a) or b) above?
    Do I need anything to protect the Topfield from a lightning strike to the roof aerial?
    Ta muchly :thumbsup:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,616
    Rainham Essex
    +2,546
    Personally I use 2 of These as they offer an unlimited warrenty on anything plugged into them if the worst should happen. They will also replace the unit if it get killed by a surge. These protectors are better than the standard ones due to the warrenty offered and they also give EMI & RFI protection that can improve both sound and picture quality if your mains suffer from these problems.
    Basically they give me piece of mind for all my equipment. Should the worst happen at least I know Belkin will be the ones paying to replace everything an not me :thumbsup:
    Mark.
