Lighting
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by windyindie, Apr 14, 2005.
  1. windyindie
    windyindie
    :hiya: Hey all,
    My question is not a technical one as such. I want advice on how to light a party for filming purposes. I have filmed wedding parties in the past, and the lighting used was a row of domestic bulbs on a tripod bar rig. Very harsh!
    Is there something better? Are mini lights on camcorders strong enough to get a decent picture from a darkened dancefloor - good enough for paying customers that is?!
    many thanks in advance... :thumbsup:
    WI
  2. Roy Mallard
    Roy Mallard
    hire in a 2kw blonde or a set of 800w reds, bounce the light off of a white ceiling or wall or use diffuser gels over the lamps, this will look less 'lit' more natural, it won't blind folk and will give you a more even illumination accross the room.
    This is really the only way to do it right, if you have a lamp on the camera then your subjects will be very aware that they are on camera, so the candid stuff won't work.
    Good luck
