Lighting for a Plasma Screen
Discussion in 'Home Cinema Buying & Building' started by mjb-av, Nov 4, 2005.
  1. mjb-av
    mjb-av
    Oct 30, 2005
    541
    Far, far away
    +47
    Hi Folks :) ,
    I have read on an American forum that lighting behind a plasma screen can enhance your viewing pleasure, it suggested daylight lamps at approx 18watts. But I can’t find the site now.
    Can anyone recommend suitable lights/colour, etc?
    What are you using to enhance your viewing pleasure?
    :hiya:
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    The "compact fluorescent" lamps are quite suitable because they don't give off a lot of heat. You can place lamps either behind the screen, or behind the viewers - we have a 3-seater leather sofa, and I've placed a couple of 6W compact fluo's behind that, with quite good effect. Placing lamps behind the screen minimises the risk of reflections. All I used were the cheapest lamps I could find (small white ones @ £4.99 each) because they're hidden anyway.
  3. mjb-av
    mjb-av
    Oct 30, 2005
    541
    Far, far away
    +47
  4. Son of Shaft
    Son of Shaft
    Mar 11, 2005
    157
    Breda
    You can try CCFL's. http://www.sharkoon.com/enghtml/illumination.htm
    These are lights that are often used in PC case mods. Just connect the inverter to a 12V mains adapter and they work.
    Going to use them behind a rear-pro myself. They are pretty cheap too and should last for at least 20.000 hours.
  5. cR4cKF0x 5TevE
    cR4cKF0x 5TevE
    Sep 7, 2004
    2,699
    St Merryn
    +583
    Just 'installed' my new Ikea TRETTIOEN lights with my Hitachi 42PD7200.
    They look fantastic and do seem to make a difference.
    I went for the Blue option to be 'sympathetic' to my living room decor, they produce a really atmospheric glow in a dark room.
    One other thread suggested there weren't many of these lights left, but Ikea in Wednesbury had loads in stock today.
  6. kaisersozeuk
    kaisersozeuk
    Mar 9, 2005
    92
    11
    +3
    Hi Gravy
    Any chance of a pic to see the lights in action?
    Soze
