Light/lamp dimmer control
dawilliams
Hello
Can anyone please tell me if there is anything on the market that will allow me to do the following:
I have room with a ceiling light, controlled in the usual way by a simple dimmer, and a lamp plugged into a socket. Is there anyway to control both, independently from a wall switch. Effectively a two gang dimmer, one to control the ceiling light via wire and one to control a socket dimmer on the lamp remotely.
I know it's possible to do this via a remote control but I'd rather have an wall switch to do the job.
Thanks for any help.
schford
Get a Rako Dimmer module for the ceiling light and one for the lamp and then a RAKO wall switch.
I am sure there will be other ways of doing it as well.
Stuart
dawilliams
Thanks, Stuart.
That looks ideal; but a bit more than I was wanting to pay.
Does anyone know of any cheaper alternatives?
tobinharris
Looks like this dual Z-Wave dimmer switch allows 1 switch to control connected load (your ceiling lamp) and another to control another load wirelessly (your lamp)
http://zwave-products.co.uk/shop/ar...-_-Transmitter.html?shop_param=cid=98&aid=84&
You'd then need a dimmable lamp module plugged into the wall, and paired with the Z-Wave wall switch.
ACT HomePro ZDP210 RF / Z-Wave UK Plug-In Lamp Module - Detailed item view - Control - Z-Wave Products (UK) - The UK's Leading Z-Wave Store
Total cost is about £130.
T
