Light Guns And Projectors
Discussion in 'General Video Gaming Chat' started by skimber, Dec 15, 2001.
  1. skimber
    skimber
    Dec 1, 2001
    205
    19
    Does anyone know if the light guns you can get for some games work with a projector?
    I'm not entirely sure how they work anyway!!
  2. annefromuk
    annefromuk
    Look on How Stuff Works, this will explain how the lightgun works
    As to working on a Projector, I was going to say no, but I then read on IGN that there has been reader who got a lightgun to work with Rear Projection TV.
    So hopefully someone else knows in this forum if they work.
    Anne
  3. annefromuk
    annefromuk
    I just found this on a Newsgroup posted by Isaac Kuo
  4. skimber
    skimber
    Dec 1, 2001
    205
    19
    Interesting... Thanks for that!! :)
    I've got a DLP projector on order so it looks like I won't be able to use one, just thought that it might be fun shooting at life-size enemies :D
    I might still see if i can borrow one off a friend just in case it works!
    Simon
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,193
    +1,236
    I answered this days ago in the projector forum.
    It should be fine as long as you use a crt projector not a digital panel model. Avoid any scaling or deinterlacing so you'll have to use a bog standard video res interlaced sugnal ( s-video/composite or maybe componenet on some units). Avoid any units with built in deinterlacers/ scalers also.
    you'll need the room to be optimum with regard to ambient light to get the gun to properly read the screen.
  6. Guest
    So why doesnt a light gun work on my widescreen telly ? It's not a 100hz tv. I tried it in every mode...4:3, 16.9 but no luck. Can't see why it would work on a CRT but not on my ws.
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,193
    +1,236
    duff gun perhaps. I've used a Gcon no problem on my 32" widescreen. I assume you've connected it up correctly?
  8. museumsteve
    museumsteve
    Jan 28, 2001
    7,994
    4
    Nth Hampshire
    +1,106
    MrD's right..there's no reason why it wouldn;t work unless (if you're using a Guncon) you haven't plugged in the yellow lead in..(which should be attached to your gun)..
