Light bleed in right corner
Discussion in 'LG TVs Forum' started by Ahabaz, Jun 15, 2019.
  1. Ahabaz
    Ahabaz
    Jun 15, 2019
    2
    4
    Egypt
    Hello every one ,
    I got a sudden light bleeding in right bottom corner that's very visible in dark views like black bars while watching movie for example or even any dark sense in this area
    I contacted LG In my country and they told me it's normal but I Unconvinced
    My Model is 55SK8000PVA
    Is that normal and how can i fix this bleeding
    Regards
  2. TheCrazy
    TheCrazy
    Jul 16, 2018
    23
    london
    +3
    It's not great at all. Some light bleed is kinda common among edge lit tvs. That does seem a bit bad though. Who did you buy it from? Ask the retailer to switch it.
  3. Ahabaz
    Ahabaz
    Jun 15, 2019
    2
    4
    Egypt
    Unfortunately the LG Customer Service told me that is within normal range and it's normal so no replacement needed
    I'd like to ask if put paper between the screen and edge in this corner can I got it fixed ??
  4. TheCrazy
    TheCrazy
    Jul 16, 2018
    23
    london
    +3
    You didn't buy it direct for LG did you? Tell the place you bought it from the store itself to replace it.
