Lifting projector
Status
Not open for further replies.
simon69
I remember reading soemthing about using a lifting genie or something from a hire shop to lift projectors to the ceiling, does anyone know the web address or the organisation which hires them.
X3ELS
Just go to any HSS hire shop, they are nationwide i believe and they do a range of genie lifts depending on the weight you need to lift.
Good Luck!!
Roland @ B4
A Genie lift is what you want.
HSS seem to be the most popular you need the "Lift and shift department" not always in the same location as the hire shops.
here the web page HSS - Lift and shift
simon69
Thanks for that, I lifted the projector up on my own, but I dont want to try get it down like that.
Status
