Lifting a BG808s
Discussion in 'Projectors, Screens & Video Processors' started by Thunder, Dec 1, 2004.
  1. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    The time is coming to ceiling mount my new CRT :D , the ceiling beams are reinforced, the unistrut is in place and the threaded rod has been cut to length, but how the hell do I get it up there :eek: !! I have been recommended by a tool hire company to use a "genie lift", its like a mini forklift on a trolly normally used to lift air con units into place, it will lift up to 250kg to 3.5m high which is plenty for me :) . Does anyone have any further advice on kit that would be better or will the genie do the job :confused:
  2. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,065
    3
    +7,865
    The genie is the best tool for the job.
  3. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Cheers phil, still chuffed with your 808? :)
  4. scott33b
    scott33b
    Aug 3, 2004
    68
    Just mounted my 801s on to the ceiling last night. Cheapest way is 2 mates and a case of beer!!.
  5. benwillcox
    benwillcox
    Sep 21, 2004
    295
    Telford
    +22
    Any chance of some pics showing how the unistrut, threaded rod, and beam reinforcement looks, for when I try to stick my 801s to the ceiling? :smashin:
    Cheers,
    Ben.
  6. jacovn
    jacovn
    May 21, 2004
    62
    Netherlands
    +4
    You could have bought a barco CM100 projection lift. Than it is a one man job (ok a 2nd one to put the nuts onto the bolts..)
    Jaco
