Hi there, got one of these myself.
Press and hold 'set' while doing that, press 'TV'
Use the up/down keys to select Sanyo, then left and right to try the different combinations (press OK to try one), there's about 30 for the Sanyo (!), so it's a case of trail and error.
Write down the ones that work, and pick the one that has the most working functions, you can fine tune the rest (usually) via the learn key, if you have the original remote.
I say usually, because I can't get any learned key to work with my Panny DigiBox, so I'm stuck with the preset, which bizarrely doesn't seem to have included the 'i' info key
, although everything else plays ball, mostly.
