Liberty UltraCap THX Speaker Cables
Discussion in 'Cables & Switches' started by jrpavel, Jun 13, 2004.
  1. jrpavel
    jrpavel
    Jan 25, 2004
    178
    16
    Are Liberty Speaker cables (UltraCap or ExtraFlex, say) any good?
    They seem reasonably priced and designed for use by system installers.
    What is more, the UltraCap range is THX Ultra certified!
    I want to hook up my Proac Response 1SC / CC1 and don't want to spend excessively on wires, if I can avoid it.
    If you think that the Liberty Cables would be unsuitable, what would you suggest instead? (QED, Chord). I also have 10-year-old some Audioquest Indigo 2 solid cable at the bottom of the cupboard.
  2. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    243
    I am installing Liberty on advise from the place where I bought my bits.
    As things got a little tight towards the end of my purchasing limit, and that I had forgotten about speaker cable they said to go with Liberty.
    The other option they advised was Chord, but at 10 times the price I had to settle for what I could afford.
    The cable itself looks good, and shouldnt give any problems.
    Fish
