LH-C6235 Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Quozt, Apr 19, 2005.
  1. Quozt
    Quozt
    i have a LH-C6235 combi with dvd and video... worked fine until today when it suddendly went on standby now it wont stop going on stanby everytime we turn it on... theres no setting for auto standby we think and we have tryed half tryed playing a dvd and it just goes on standby
    anyone have this trouble or any advice?
    :lease: :lease:
    thanks
    Dom
  2. mortimp
    mortimp
    I have the same problem with mine it is caused by IC705 and IC706 both 5v Regulators. If you remove the top of the player you will see a group of about 6 heatsinks towards the back of the unit that is where you will find the offending items,if you turn the unit on you will find that the two heatsinks with the regulators on get very hot,I sprayed mine with freezer spray,and it stopped it going in to standby,hope this helps.
    good luck
