Quantcast
LG43um7400PLA - strange screen with HDD recordings.
clubsuite
I have just bought the above smart TV (my first). I have a Panasonic blu ray player and a Panasonic DVD/HDD recorder which I have connected up with HDMI cables. The TV had no problem finding the devices and I can play discs fine. When I went away, I recorded some programmes as per usual on the Panasonic player. When I came to play them back, the screen looked like the attached photo. I have absolutely no idea why. The images in my library of recordings on my Panasonic appeared the same as well on the TV screen. Does anyone have any idea what the problem is?
clubsuite
Well, I solved this one myself after LG and Richers Sounds couldn't. The DVD HDD was set to NTSA (from a disc I had previously watched) instead of PAL. I changed it over and it works fine.
