Lg32lx2r to pc connection
Discussion in 'LCD & LED LCD TVs Forum' started by joldinash, Mar 10, 2006.
Tags:
  1. joldinash
    joldinash
    I have an LG32LX2R and want to connect it to my pc. Does anyone know the best way to do this and more importantly, all the different settings. What confuses me is things like 1:1 pixel mapping (wot the **** is that?!)
    LG32LX2R
    PC WITH ATI RADEON 9250 128MB
    SAMSUNG HT-UP30 - 5.1 HOME CINEMA SYSTEM
    SKY+
    PS2
    Cheers!
  2. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    DVI out to DVI on the TV, set 1360x768 on the ATI. The TV should show 1:1 pixel mapping
    Or VGA to DVI on the TV, set 1360x768 on the ATI. The TV should show 1:1 pixel mapping.
    Make sure you select the DVI inputs with the >PC next to it (press right)
    If you can't send 1360x768 1024x768 still looks great, no vertical stretching just horizontol, still perfectly readable. Or you could select the 4:3 mode (1:1)
    It's dead easy, just don't go and select any higher than 1366x768
  3. joldinash
    joldinash
    Thanks badbob. I'll try that once i've got my new dvi-d cable (need 5m)
