Hi all, I have a lg 226wtq monitor that has vga and dvi inputs, i tried to connect a 5 metre vga cable to the monitor and got terrible ghosting so i tried putting a vga to dvi converter adapter on each end and connected pc to moniter using a palit 9500gt super+ 1gb, when i tried to connect to the monitor it wouldnt go in, on closer inspection the dvi cable that came with the monitor has a thinner C5 pin (the widest pin in the connector), so i snipped the C5 pin down to size plus i had to cut out pins C1-4 then i managed to insert into the moniter but got no image except a check cable connection on the monitor, is it all down to the cable and why the different size C5 pin.The cable i got of ebay that strangly has got expandable cable sleeving over solid cable with chokes at both end, or is this trying to hide to cable specs thats printed on them.Any help on this will be appreciated.
