LG14 Plasma - DVD shows B&W picture on S-video - help!
Discussion in 'Plasma TVs' started by TP2K, Feb 5, 2003.
  1. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    Hi all;
    Just set up my new spanking LG14... and for now I have an old S-video cable from my previous CRT which I will use until the weekend - however, the picture is black & white!
    Probably something daft (I Hope) - but can anyone help me please?
  2. marts62
    marts62
    Jan 24, 2003
    127
    hemel hempstead
    +3
    Has the lead come loose? The Scart came loose in Comet when I was testing and all I got was a green tinge to the whole screen.
    A scart from the Video to the tuner via an Argos scart switch works okay for me. Not brilliant but viewable.
    Would be interested to know how it turns out, TP2K. 3 days later and I am still tweaking my LG14. I wish there was a test card to help with setup.
  3. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Check for bent pins and make sure the dvd player is set to output svideo and not rgb.
    Marts, for a testcard try the THX tests on Terminator 2 for example.
  4. marts62
    marts62
    Jan 24, 2003
    127
    hemel hempstead
    +3
    Thanks bobones. I'll do just that.
  5. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    Must say I am baffled; the cable and DVD player are the exact same (no setting changes seither) as what I disconnected from my CRT just an hour ago which was fine...
    So, I don't understand what's happening - I don't suppose any owners of LGs know if there is some sort of menu setting on the display which I am mis-setting? Something along the lines of accepting S-video?
  6. marts62
    marts62
    Jan 24, 2003
    127
    hemel hempstead
    +3
    There is AV1, 2, 3, RGB-PC, component.
    AV3 should be your S-Video, using the TV/AV button on the remote.
    ...trying to help...
  7. jmack
    jmack
    hi not sure if this helps but my other crt shows a black and white picture because it cant accept ntsc,
    is there a menu on the lg to accept ntsc or auto, maybe you have it on pal
    hope this helps
    keep us updated
  8. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    - being a little dizzy here;
    I have an S-Video - Scart lead and was connecting via a Scart input on the tuner box.
    The AV3 socket is an S-Video connector so I guess I need a new cable (S-Video - S-Video)!!!
    :blush:
  9. marts62
    marts62
    Jan 24, 2003
    127
    hemel hempstead
    +3
    Does S-Video for the Vid<->Tuner work better than cheapo Argos scart (gold ends)?
