LG14 plasma and buzzing
Discussion in 'LG TVs Forum' started by CrumpetMan, Apr 21, 2003.
  1. CrumpetMan
    CrumpetMan
    Aug 12, 2002
    107
    I got an LG14 plasma today and it buzzes! It happens even if I disconnect all inputs so I'm guessing it's to do with the power supply or something like that.
    If I put my head behind the screen it is very noticeable, if I have the volume low to medium and sit 10 feet away I can still hear it. My girlfriend says she can't hear it as long as there is some other background noise or there is sound coming out of the speakers.
    Has anyone else noticed this problem with this model or the LG17? I am wondering whether to get it swapped out or just return it for a refund and get an LG17 instead.
    Otherwise I am enjoying the display very much, I can't bear to look at my old 28 inch widescreen now!
    TIA.
  2. KevinWood
    KevinWood
    Dec 9, 2002
    102
    19
    Stirling
    Sounds like you have a faulty screen. I have had my 14 for 5 months now and it has no buzzing sounds at all!
    If you can, I would probably advise you go for a 17 as it is a newer and slightly better spec'd model, although it doesn't have the tuner (which in my opinion is a great bit of kit as it gives plenty of connectivity options with no noticeable degradation of signal!!).
  3. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Well I have the 17 and it is silent. No buzzing at all. Sounds like it could be faulty or a good reason to return it.
    If you can take it back and get the 17 I would. It has twice the contrast and superior brightness to the 14.
  4. CrumpetMan
    CrumpetMan
    Aug 12, 2002
    107
    Well it is definitely going back. Once the refund is sorted I will take a look at the 17 from richer sounds. Thanks for the information guys.
