LG XCA16 or PIONEER X-EM11
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Janner66, Mar 5, 2013.
LG XA16 or Pioneer X-EM11
Poll closed Mar 7, 2013.
  1. LG XA16
    0 vote(s)
    0.0%
  2. PIONEER X-EM11
    0 vote(s)
    0.0%
  1. Janner66
    Janner66
    Aug 10, 2009
    94
    Plymouth
    I was hoping somebody could offer some advice on these two relatively cheap mini hi-fi systems.
    It will be for the bedroom to listen to music whilst I fall asleep, therefore the sound levels will be quite low. They both have everything I need apart from the Pioneer doesn't have DAB radio but I can live with that.
    Here are the links:
    LG XA16 DAB Micro Hi-fi System - Hi-Fi & micro systems - Audio & Hi-Fi - Technology - Sainsbury's
    £59.99
    or
    Pioneer X-EM11 | Mini System INC Speakers | Richer Sounds
    £49.95
    Apart from the DAB they appear to be quite similar. Pioneer always used to be a good make and I have many LG products around the house and have always been happy with them.
    Any thoughts? Thanks.
  2. Janner66
    Janner66
    Aug 10, 2009
    94
    Plymouth
    LG XCA16:
    Accessories included
    Remote control
    Batteries included
    Yes
    Body material
    Steel/plastic
    Brand
    LG
    Charges iPod
    Yes
    Colour
    Natural
    Country of origin
    Indonesia
    Display
    Backlit LCD
    Formats played
    What's this? CD,CD-R,CD-RW,MP3,WMA
    Length, width, height
    10.5 x 20.5 x 20cm
    Manufacturer's guarantee
    1 year
    Number of preset stations
    50per band
    Power supply
    Mains
    Product number
    XA16DAB
    Radio pause function
    No
    Radio rewind function
    Yes
    Radio tuner
    DAB/FM/AM
    Remote control
    Yes
    Speaker output
    What's this? 2 x 5W (10W)
    USB port
    What's this? Yes
    Weight
    3.99kg
    iPod docking station
    What's this? No
    Customer Review
    Pioneer X-EM11
    iPod/iPhone Dock?
    Does the system feature a built-in or separate iPod/iPhone dock?
    No
    USB
    Number of USB sockets.
    Coaxial Inputs
    Number of coaxial digital inputs to input digital sources such as DVD player.
    Optical Inputs
    Number of optical digital inputs to input digital sources such as DVD players.
    Active Subwoofer Output
    Does it have a separate connection for an active (powered) subwoofer?
    No
    Dedicated Port
    Does it have a dedicated port for extras such as iPod dock, Bluetooth or DAB radio?
    No
    Audio Inputs
    Number of audio inputs on both front and rear of unit.
    HDMI
    HDMI offers the highest quality, digital connection. The numbers given relate to the number of HDMI inputs/outputs.
    No
    CD Player
    Is a CD player fitted?
    Yes
    DVD Player
    Is a DVD Player fitted?
    No
    Blu-ray Player
    Is a Blu-ray Player fitted?
    No
    HDD
    Is a HDD (Hard Disc Drive) fitted?
    No
    HDD Size
    The higher the figure the greater the amount of music that can be held on disc.
    NA
    Power Output
    Maximum power output per channel - RMS into 8 ohms.
    10 x 2
    Tuner Radio
    Type of radio built-in. DAB is Digital Audio Broadcasting.
    FM
    Remote Control
    Is an Infra-red remote included?
    Yes
    Smart Remote Control
    Can you use a Smart Phone (iPhone or Android) to control the unit?
    No
    Dimensions
    Dimensions of unit (W x D x H) mm.
    152 x 215 x 175
    Speaker Dimensions
    Dimensions of speakers (H x W x D) mm.
    175 x 135 x 198
    Weight
    Weight of unit,unboxed, in KG.
    1.4
    Speaker Weight
    Weight of speakers, unboxed, in KG.
    1.3
  3. Nenillo
    Nenillo
    Mar 21, 2013
    2
    Hello, I'm interested in XEM11 Pioneer or Panasonic SC-PM200EG-S. I prefer the Pioneer, but say they do not read MP3 CD (MP3 only in usb) I do not know if it's true or not, if it were true, I would go for the Panasonic does read mp3 on cd and usb and the Panasonic can configure the Flat (treble and bass). Have you already bought one?
  4. Janner66
    Janner66
    Aug 10, 2009
    94
    Plymouth
    I bought the Pioneer but I am taking it back because the CD player is very noisy. I wanted it to listen to music as I am going to sleep but on the lower levels you can hear the CD player over the music. I suppose you get what you pay for.
    Also it does not have an alarm which I wanted.
  5. Nenillo
    Nenillo
    Mar 21, 2013
    2
    In the end I bought the Panasonic SC-MP200, easily and completely.
    Nota: The pioneer xem11 if you alarm.
