calaudude
I got now my LG 75UH780v which is quite possible the UH770V in a 75" upgrade or like the 75" HU8500 less 3D support
I was told the UH780v has the same 3D pannel like the UH8500 so technical it should be possible to enable 3D so I went into the service menu / EZ adjust there there I saw
Dislplay mode was 2D and Dolby Vision was off
you can check all settings here
https://photos.google.com/share/AF1...?key=ZTRJUDJuTUdEMTF3U1FNQnZDSkJacEtTdmFzQk1n
in Tool Option5 I see 3D display type : 2D
in Tool Option9 O see Dolby Vison HDR : OFF
so its quite strange as this TV is advertised with Dolby Vidion Support
When I want to change Settings I see that most lines are greyed out and cant be changed for some reason
Anybody know how to activate these grey lines so I can change the Values
to enter service menu I installed anymote on my IR-Mobile and selected there LG/TV and service remote
PIN to enter Service is 0413
other PIN to enable settings I saw somewhere for LG should be 8471
so anybody did try to enayble hidden stuff in service menu for the new super LCD LG WebOS3 class 2016 series?
