Question LG TV wont work with wireless headphones
Discussion in 'LG TVs Forum' started by satmanuk, Apr 24, 2016.
  1. satmanuk
    satmanuk
    Jun 11, 2015
    88
    11
    crawley
    +8
    hi all,
    So i brought (upgraded) a LG65inch tv from a 55inch (see old post) when the old tv was showing all crazy images and let me down at xmas after 4 months.
    At the time i had the maplin wireless heads-phones and worked with my panny all ok for 3 months.
    When i tried on this tv, i got sound and just strange interference noises on all channels.
    SO i gave that set away and this week brought a thomson made headphones and the same thing is happening. Is it a tv issue?
    its on software 04.00.35
    Model LG65UF950V
    WORKS ok if i use wired headphones, as tested with iphone lead and some old headphones that i had from making music. So why will it not work with wireless based headphones?
  2. satmanuk
    satmanuk
    Jun 11, 2015
    88
    11
    crawley
    +8
    can a admin spell check the tittle lol should be wireless not wirless
  3. JayCee
    JayCee
    Jan 20, 2004
    23,192
    Lanarkshire
    +2,483
    I'm sure I read a post on here previously concerning an LG Tv and Bluetooth headphones that only certain models of LG Bluetooth headphones could be used.
  4. satmanuk
    satmanuk
    Jun 11, 2015
    88
    11
    crawley
    +8
    not on about bluethooth at all
    simple wireless that base plugs into the headphone socket
    randomly i think i solved
    had to put on audio out. then this cuts of sound on tv
    then two headphones on and i got sound
    if u put headphones on first then pick audio out would not work
  5. droidlike
    droidlike
    Aug 21, 2015
    491
    46
    +129
    It's well known that on lg tv do work only lg bluetooth sets ...I've seen it on my tv lg 42la860v...it works only with lg sets...I got hbs730 and it works great
    Alternatively you can get a bluetooth tx like blutos-X telme2
    So you can use different brands bluetooth sets
