JBThirty33
Looking for some advice please. Any help would be greatly appreciated.
I have an LG 49uj634v, and for the last 12 months have had it hooked to an LG sound bar and made use of the sound sync option allowing me to control the sound bar volume with my tv remote.
Now I appreciate I should probably have done some more research but I saw a very good deal on a Sony BDV E4100 5.1 surround system. I've hooked this up to my TV but I'm having some issues, and I'm assuming it's due to the different models of TV and surround.
I have managed to set the surround and TV to turn on using the same remote, how we when the surround turns it never defaults to the TV input - it goes straight to the home screen and says "setup" on the lcd screen. I then need to change the input manually every time I turn on the TV.
Furthermore, the 5.1 isn't always active. For example when opening Netflix, you can normally see if will say 5.1 next to the thumbnail if it is available. This doesn't appear unless I go into my tv audio settings and change PCM to Auto, which I need to do every time too.
This is infuriating me and right now I'm Co sidering selling the Sony system in favour of an LG system. Should I be doing something differently?
Thanks and apologies for the long post.
