jimox1999
Hello all, Ive just bought the Canton DM55 Soundbase from Richer Sounds and its great, but it has a niggly fault - when I press the Canton remotes Volume Up/Down buttons my LG 42LB55-OV's reacts and items that are part of the tv OSD come on ( the Quick menu; the Mute symbol or sometimes something that looks like a Factory reset menu/System info ) - I can remove them using the LG remotes Back button or the Mute button for that icon.
If I leave them they go after about 50 seconds - except for Mute symbol which stays.
I've contacted Canton - no reply yet; Richer Sounds and LG UK - both not seen this before.
I've tried clearing the Canton remote but to no avail.
Also it doesn't do this if I program my Sky tv remote to control the Cantons volume.So has anyone got any idea how to fix this please?
