LG TV... On vs Off remote signal.
superdave67
Is there a separate On vs Off remote signal for the LG TV series? Specifically, the 60SJ800 model? I have my office setup so that if there is any motion, it (Bestcon RM4C Mini Universal IR Blaster on Amazon) turns ON the TV. While that works, it also turns the TV OFF, when it detects motion. So have had to disable that routine (Alexa).
Is there a way (or other device) that is capable to sending an ON code separately from an OFF code?
Thanks!
Paden
Hey superdave67
I use a Harmony remote on my C1, whch sometimes give you access to functions not existing on the original remote, that has the power toggle but also has discrete commands for off & on, so they must exist.
Have you come across this site before, there might be someting of use to you there.
Cheers, Paul
superdave67
Thanks Paul, I'll check out those codes and see if I can modify the signals from the Bestcon IR Blaster. Does you Harmony remote work with Alexa or other other routines?
Paden
I don't use it with Alexa but I believe it can be intergrated :)
Cheers, Paul
Prey + Bullet Train reviews, Heat 4K + Event Horizon 4K and all the latest movies and TV news
