Question LG TV HDR for Xbox one x
Discussion in 'General TV Discussions Forum' started by Hedgehead, Aug 25, 2018.
  1. Hedgehead
    Hedgehead
    Aug 25, 2018
    2
    Uk
    So I just bought a new LG LG 43UK6470PLC 43" with the intension of using an Xbox one X with it. Now I've seen loads of videos and tips on how to enable the full HDR for this by going into the settings general tab and having the option at the bottom. The only problem is the TV doesn't appear to have this? It's a full 4K HDR ultra HD TV and the new 2018 model, am I missing something?
    I've watched this guys YouTube video
    LG TV - Xbox One X - HDR & 4K Fix
    but my TV does not have this option in the menu?
  2. Littleted@gmail
    [email protected]
    Jun 12, 2009
    180
    Leeds UK
    +12
    in your settings if its full HDR you should have an option on the TV that allows you to configure it
    you need this window
    https://www.forbes.com/sites/kevinm...p-how-to-enable-hdr-on-an-lg-tv/#4e88430e6786
    once enable the XBOX works, if you dont have that window then i can only think your TV is not doing proper HDR but the active kind where it simulates it.. but i cant be sure
    Bot my LG b7 and C8s have this screen and i only got what you showed in your screenshot when these options were off.
    Good Luck
