LG TV connection to LG Home Theater
AdrianPC
HI All
I have a LGTV model 50LA 6230 and a DVD Home theater Model. HT406TQ. I was wondering if I could listen to the sound from the tv through the external speakers rather than the TV built in speakers?
This is the connection behind the TV
This is the connection behind the home theatre
Thanks.
Adrian
It would appear that your LG Home Theater only offers one (stereo) 'AUX (L/R) INPUT' audio connection. So unless your LG 50LA6230 TV offers a headphone output port, it's going to be pretty difficult to connect the two devices together easily...
And you wont get genuine surround sound, only matrixed.
AdrianPC
Thanks.
grahamlthompson
You need a optical to analogue (DAC - Digital to Analogue) converter and a cable to connect to a amp input. The picture of the rear is too small to check what inputs it has so without this can't link to a suitable cable.
It looks as if it only has outputs.
You need a new amplifier. Most any cheap stereo amplifier and speakers will do. Or a Bluetooth transmitter and a pair of bluetooth speakers.
Cheapest I can find
Look for a cheap used one with speakers on e-bay. Most will sound superior to the TV speakers
Hi again @AdrianPC,
So it looks like your TV has a 3.5mm diameter headphone output. Which means if you get hold of a '3.5mm Male to 2x RCA Male Jack Stereo Audio Adapter Cable', such as this: -
...you can connect both of your devices together...
JayCee
The OP's pic shows His Home Theater does have an RCA Phono Aux input (item 5 in his diagram) which as SeeMoreDigital states will take the headphone output from the TV's headphone socket and give him stereo.
AdrianPC
Hi all
What you mentioned TV's headphone socket , do you mean ' H/P out '?
Thanks you everyone.
Regards
Adrian
JayCee
Yes, “H/P Out” is the headphone socket so the 3.5mm stereo minijack plug into there and the other end with the RCA Phono plugs into the Aux input on your amp and you’re good to go.
grahamlthompson
On most TV's plugging something into the headphone out mutes the TV speakers. That's why there is a toslink output. The DAC may be used to connect to the red/white audio in on the TV.
The OP has stated the following: "I was wondering if I could listen to the sound from the tv through the external speakers rather than the TV built in speakers?"...
grahamlthompson
Still think the DAC is the preferred option . The headphone output is too high for line level inputs and the wrong impedance for the line level inputs on the amp. The DAC will produce a 75 ohm fixed level matched impedance to the amp stereo audio inputs.
JayCee
I'm well aware of that but please read post #10 and the DAC needs to be plugged into the Aux red/white audio in on the OP's amp...not the TV.
JayCee
The DAC and optical lead is an extra cost to the PM (although he may not mind this).
The headphone Output level can be adjusted by the TV's remote.
AdrianPC
Hi All
I used the cable below and didnt work. Do I need the 2x male RCA cables instead of the 3x RCA?
AdrianC
AdrianPC
Thank you everyone for you recommendations. Now I can hear the sound from my tv through my home system using the 3.5mm stereo mini jack to 2 RCA .
Nice one... And thanks for reporting back ;)
