I have a 50" LG, it is a few years old now but it is now coupled to a JVC sound bar. The problem is that when the TV is turned on the IR remote on the sound bar is really weak, When the TV is off the soundbar remote works fine but weakens as soon as the tv is turned on. Also the remote on the tv itself is really intermittent. There are no blockages between the remotes and the IR sensors on the units. I thought that remotes operated on light. Can the TV cause the remote on the soundbar to not work correctly? If so how can I combat it?
The sound bar and tv are connected via optical cable.
