LG Tuner box ... are all inputs RGB enabled?
Discussion in 'LG TVs Forum' started by TP2K, Jun 22, 2003.
  1. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    I have the LG14 and tuner box, and am having a fiddle with connections.
    I have the following to connect;
    DVD Player/Recorder
    Telewest DigiBox
    The Tuner box has two scart inputs which, ideally, I would like to use. Does anyone know if AV1 and AV2 on the tuner box will both accept an RGB signal?
    I have the Telewest box set to output RGB and connected to AV1, and the picture is pretty good.
    However, rather than use Component for my DVD I want to use RGB scart as, to my eye, the picture is more colourful and sharper - however, connected to AV2 on the LG tuner box, the resulting picture is not that of the connection originally through AV1... The DVD is set to output RGB, but through the second input on the tuner box it is not as good as previously!
    My connections are thus;
    Telewest Digibox (RGB scart) -> LG Tuner AV1
    Telewest Digibox (VCR scart) -> DVDR L2
    DVDR L1 -> LG Tuner AV2
    Any help appreciated!
