LG & SONY LCD's
Discussion in 'Sony TVs Forum' started by nobbydog, Sep 18, 2003.
  1. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    A supplier today told me that an LG lcd was as good as a Sony as Sony make the screens for LG. Anyone know if this is true. If so it makes the LG lcd's look good value compared to some of the higher priced Sony's.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    It is possible but if the supplier sells LG and not Sony then there is a hint!
    Sharp are the Best LCD's and fall somewhere between the 2 in terms of price have a look at the Aquos range and see what you think!
  3. andya
    andya
    Oct 25, 2002
    2,432
    48
    manchester
    +35
    i believe lg provide sony with the screen
  4. ConceptVBS
    ConceptVBS
    He's wrong.
    He should've said that the Sony is as good as LG. LG provides all the LCD's to Sony.
