LG Smart Wi-Fi 3D BP630 Blu-ray Player with Miracast
Discussion in 'Blu-ray & DVD Players & Recorders' started by Blujelly, Aug 17, 2013.
  1. Blujelly
    Blujelly
    Jul 26, 2012
    99
    11
    United Kingdom
    Afternoon,
    I currently bought the above Blu-Ray Player. Im a little bit confused with the Miracast.
    I am just wondering how can I connect my iPhone 4S to this? it has also come with the NFC tag.
    Also it has a optical out cable, yet my 5.1 doesn't have the optical input cables, is there anyway I can get round this? Or does any know of any optical > Aux leads?
    Many Thanks
  2. MAX1210
    MAX1210
    Mar 9, 2009
    4,525
    3
    +1,239
    Miracast is a function of the Android 4.2 operating system, so will not work with your iPhone (it allows you to connect you smartphone/tablet to the device so you can see the display of your screen on your TV)
    You can get Optical → AUX (phono) adaptors, but not leads. You will to make sure it converts the right way like this one LINDY SPDIF Digital to Analogue Stereo Audio Converter: Amazon.co.uk: Electronics you will then need an optical cable and a 2 phono - 2 phono cable.
  3. Blujelly
    Blujelly
    Jul 26, 2012
    99
    11
    United Kingdom
    Thanks for the information I got the converter I needed from this info!
