LG SL8YG and passthrough resolution with Shield 2019 Pro
djnield
I've just bought the LG SL8YG and connected a Shield pro to the bar as my Samsung TV only has arc.
When the shields resolution is correctly set at 4K 60 Hz I get a black screen that flashes on and off. If I reduce the resolution to anything 24Hz or below it all works as should.
Shield works fine directly into the TV as well as with other soundbars. I even bought a certified 2.1 hdmi cable on the off chance but have the same issue?
I've a support case open with LG in the hope it's just a software fix.
Anyone witnessed similar?
