LG & Sky + Box
Discussion in 'LG TVs Forum' started by pablow, Oct 21, 2005.
  1. pablow
    pablow
    Oct 21, 2005
    10
    Having just purchased a new Plasma i am trying to find out the best way to connect my Sky + to my Plasma.
    Plasma has
    S-Video
    Component
    RCA
    RS232 - rgb?
    Sky + has
    S-video
    Rs232?
    Scart
    Sorry if this is a real simple one but being new to all this it is hard to decide which is the best combination. Currently using the Sky through the S-Video and Audio via Optical link.
    thanks in advance :hiya:
  2. scarty16
    scarty16
    Jul 1, 2003
    1,677
    +454
    turn the sky+ to RGB in services menu and use the scart into the plasma via a scart-component lead
    go for a good quality lead
  3. pablow
    pablow
    Oct 21, 2005
    10
    Thanks really appriciate that! any recommendations on leads?
  4. scarty16
    scarty16
    Jul 1, 2003
    1,677
    +454
    Leads are a black art, choose a budget (and stick to it!!) I normally go for a brand I have heard of.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I'm afraid scarty is off the wall here, this won't work. Component and RGB are 2 different signals. S-video will be cheapest decent connection, easy too. Other solutions involve relatively expensive converter boxes.
  6. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    would you recomend s video from sky+ box to my panel over rgb scart?
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Dunno, never tried it. It's worth a try, as PX11s are well known not to be very special on RGB scart. S-video can surprise folks. In theory, RGB scart is better, in practice it can depend on how the display handles the signal. Some displays convert RGB to s-video before processing! It's not unusual in CRT TVs.
  8. stainway
    stainway
    Aug 3, 2005
    1,711
    The Hague,Netherlands
    +90
    Have no idea about the PX11, but I guess you have ordered the new PX3-4 model?
    Then scart (rgb enabled) it will give you much better picture then s-video. I did some experiments with my LG42PX3RV and a good quality scart will give you the best and cheapest results for TV viewing.But check first your sky+ box-does it output RGB signal.
