lg rz42px11 rgb only scart problem
Discussion in 'Plasma TVs' started by p0rt, Apr 27, 2005.
  1. p0rt
    p0rt
    Hiya,
    Today i received some ixos rgb only scarts. When connecting my sky plus box to the tv 'no signal' is displayed on the screen (i have made sure they are connected properly etc). the scart is connected to av1 on the tv. Is this likely to be a faulty cable or do i need to change some settings on the tv?
    Cheers.
    Chris
  2. nipbiplip
    nipbiplip
    Feb 5, 2005
    3,315
    On my Manor
    +570
    Ther's no reason why this shouldn't work. All I can think of is making sure that the sky box is set to rgb output (you'll find this in the settings menu on your sky box). Have you tried it with a 'normal' scart? If you get a picture with another scart, it could well be you have a faulty lead.....
  3. p0rt
    p0rt
    Thanks for your reply. I have tried it with a normal scart and it works fine. I had also set the output on the sky box to rgb...It must be a faulty lead..
  4. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    some of these leads are directional...have you tried it the other way round?
  5. p0rt
    p0rt
    mep,
    Thanks very much mate, you got it spot on! The picture is so much better now :)
    Am i right in saying that rgb cables are only for picture and not sound?
    Is it normal for the lg to step up the volume when using the remote? when turning up the volume is stops every 6 or 7 steps briefly...
    Many thanks
    Chris
  6. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    glad to help mate, rgb is pic only...fully wired carries sound too. don't know about other question though, you need another lg owner to look in.
    cheers
    Paul
