lg rz42px11 remote
Discussion in 'Plasma TVs' started by p0rt, Apr 27, 2005.
  1. p0rt
    p0rt
    I have only had the lg for a few days and am quite impressed so far (considering the price)
    One thing though, the remote doesnt seem that responsive, has anybody else noticed this?
    Is it normal, when adjusting the volume with the remote, for it to kind of go up in steps, every 6 or 7 notches it stops briefly
    any feedback appreciated
  2. simon33
    simon33
    I also noticed this on a set I viewed in a shop, I just put it down to a faulty controller. However, when I viewed the same TV in another shop I experienced exactly the same thing.
    I know what you mean, it's a niggling problem. I'd be really interested if anyone else has any input regarding this.
  3. Daddy k
    Daddy k
    Jul 19, 2004
    9,044
    coventry
    +1,345
    i believe its to do with the amount of ir light or something eminating from the display, all plasmas suffer from this phonomenom
  4. jucapo
    jucapo
    Nov 23, 2004
    22
    I don't have ANY problem with my LG-RZ42PX11 remote !!
  5. p0rt
    p0rt
    thanks for your replies...
    does anyone know about the volume issue, is it supposed to pause every 6 or 7 notches? it does it using the remote and when using the volume controls on the tv? I know it's not a big deal, i just want to makesure it's normal.
    Cheers,
    Chris
  6. Nikos_s3
    Nikos_s3
    Jan 16, 2005
    17
    4
    Athens
    what really annoys me , is the fact that when you press a channel button, it takes a while for it to change....my old sony crt doesn't do this, so it is a bit annoying...i try to use only the four direction button, changing vhannels in a row..:rolleyes:
  7. Carling147
    Carling147
    hello lads please have you got any tips to optimise this lgpx11 ive just got...feel a bit let down by it ...its a cracking tv i thought,,, am i doing ev right is the question i ask. tips plese???
  8. DOCTOR_d
    DOCTOR_d
    Mar 12, 2005
    194
    That sounds a bit strange ? Every LG I've seen only takes it's time swapping AV channels....
    I know this sounds funny, but have you tried changing the batteries ???
  9. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    My LG is slow to respond when I press a button on the remote, No painfully slow !, But .... I can live with this as its the tvs only fault :thumbsup: .
