LG RZ32LZ55 - HDMI to DVI problems with Virgin+
Discussion in 'LCD & LED LCD TVs Forum' started by freemaker, May 7, 2007.
Tags:
  1. freemaker
    freemaker
    Right I'm not too hot on technical stuff so here goes:
    I have an LG RZ32LZ55 LCD TV and am trying to hook up my Virgin HD box with the HDMI lead. The LG doesn't have a HDMI input so I've bought an adapter so I can plug the HDMI lead into the DVI socket on the tv. And that's as far as I can get, pathetic I know! I can't get any kind of picture to come through.
    I've gone through the channels i.e. AV1, AV2, S-VIDEO etc but nothing comes through. There is one thing different happening: when I'm going through those different channels one of them appears as "going into dpm mode", which doesn't happen unless the HDMI cable is plugged in. When I unplug the HDMI cable the channel goes to "no signal" so I assume then that this is the channel I have to be on, but something isn't right. Any help would be greatly appreciated,
  2. dchris2
    dchris2
    Mar 11, 2007
    108
    just a thought, is the dvi port on ur TV hdcp enabled? Maybe Virgin+ uses hdcp for its box
    edit: I don't think the hdmi->dvi adapter is the problem, it might be but I think it's unlikely
  3. freemaker
    freemaker
    thanks dchris2,
    as far as i can tell from searching through posts, the tv is hdcp unless anyone can tell me otherwise.
    I'd look in the manual but unfortunately everything is packed away in storage for a few weeks, and lg don't have a manual online
  4. Lewis123
    Lewis123
    Feb 13, 2006
    512
    28
    Shoreham-by-sea
    +52
    I think you have to change the TV output settings on the V+ box to HDTV. Put a scart lead in, then change that option in the tv menus.
  5. freemaker
    freemaker
    yes mate thanks but already done that. basically when I change the settings to HD HDMI the box says to "wait while we check your settings", then after a minute or so returns back to the screen with all the old settings on, as though it has checked and no HDMI signal is coming through...doing me nut in!
