LG RZ32LZ50 service menu?
Discussion in 'LCD & LED LCD TVs Forum' started by Manowar68, Apr 23, 2005.
Tags:
  1. Manowar68
    Manowar68
    Can you improve things by playing around with the service menu?
  2. katsj
    katsj
    Can you tell me how can I enter the service menu on this set? I want to activate the Greek character set on the teletext and LG told me I will need the special remote with the service menu button! Please Help!
  3. leew914
    leew914
    May 15, 2005
    204
    Essex
    +7
    Try holding the menu button on the tv set and then press and hold the menu button on the remote at the same time
    HTH
    Lee
  4. katsj
    katsj
    Thanks a lot leew it worked and I also managed to activate the Greek character set for the teletext! Thanks a lot again!
