LG RZ32LZ50 info?
Discussion in 'LCD & LED LCD TVs Forum' started by NAR, Jan 15, 2005.
Tags:
  1. NAR
    NAR
    Sep 18, 2004
    19
    Hello,
    I have been waiting for a 32inch screen that works well with a PC and has HDCP. This LG seems to have all the right connections and claims to do 1360*768 in PC mode (according to the manual).
    The picture was reasonable on the poor feed in comet (but the Sony KLVL32 was better).
    Any other info such as HDCP through the DVI connection would be appreciated.
  2. DOCTOR_d
    DOCTOR_d
    Mar 12, 2005
    194
    Just looked into this set mate, found it had no progressive scan..... So I think that's me put off....
  3. katsj
    katsj
    I own this TV set and I assure you PS is supported through DVI and more than that it makes it a perfect monitor for my PC at 1360X768 resolution! I am really impressed with my TV set! Watching DVDs played by my PC's PowerDVD is quite an experience in terms of image quality!!!
  4. Drifty
    Drifty
    Jun 14, 2005
    105
    16
    A new 32" from LG is due to appear in July/Aug the RZ32LP1D
    so the prices of the RZ32LZ50 may drop as a result / or you may fancy the new one - it looks good on paper - but I'm no expert.
  5. chic
    chic
    Jul 1, 2001
    5,982
    glasgow
    +871
    i had a look at this set and it says it has onboard Faroudja processing, so could you not feed the tv an interlaced signal and let the tv do the progressive processing rather than let your dvd player do the progressive processing as the processor in the tv would be far better than the processors in most dvd players
  6. ghorricks
    ghorricks
    Jun 20, 2005
    I'm due to get this set in a few days time and have been asking question afetr question.
    I have also had feedback from LG.
    They say the set is HD ready.
    They say it is not progressive scan.
    They say it will work with XBox 360 (HD) and Sky HD (HD).
    I say it's HD Ready.
    I say it's not progressive scan via component, BUT is via DVI.
    I say it will work properly using DVI (HDCP enabled!).
    So, could katsj please give a little more feedback on the set...
  7. katsj
    katsj
    You have a pm! :) I love this TV set!!!
