LG RZ30LZ13 or Philips 30PF9975
Discussion in 'LG TVs Forum' started by Eyeball, Aug 3, 2004.
  1. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Hi All,
    Does anyone have any comments that could help me choose between these two LCD's?
    In my mind I think the Phillips is better as it has Pixel Plus, is wall mountable and come with a seperate tuner box. The connectivity also seems to be excellent.
    Would appreciate all comments....thanks.
    S
    :devil:
  2. s2oldskool
    s2oldskool
    I've had the LG for a month or so. Not sure about wall mounting options for it, but it looks pretty good on its stand, and you can detach the speakers.
    Connectivity is fairly similar to the philps, except for no RCA component input, but DVI-D and 15pin D-sub component instead.
    All things considered I'd say the LG is a decent budget alternative to the Philips.
