LG RZ26LZ50 or lg26lx2r
Discussion in 'LCD & LED LCD TVs Forum' started by knobbs, Sep 4, 2005.
Tags:
  1. knobbs
    knobbs
    hi looking for a 26 inch lcd.
    is there any difference in picture quality between the LG RZ26LZ50 and the lg26lx2r when viewing via av1 scart on a sky digi box, mainly need it for watching sports on.
  2. Moogrose
    Moogrose
    Aug 5, 2005
    142
    Not sure about the picture quality... i would think it wouldn't be a hugely noticable difference, howeve the 26LX2R is HD-Ready (more future proof) with HDMi, DVI (wich can take a pc signal) two scarts (1 RBG), S-Video and component.
    If you had to choose between the two, i'd go for the 26LX2R, i have one, and believe me when i say you won't be dissapointed.
  3. amorenod
    amorenod
    Sep 17, 2002
    483
    28
    +41
    To me, the biggest flaw in the LZ50 range is that the component input only works with interlaced signals, ie. no prog scan.
