Lg Rz-42px11
Discussion in 'LG TVs Forum' started by Billyfergus, Jan 3, 2005.
  1. Billyfergus
    Billyfergus
    Basic question, now offshore but decided to purchase this screen from RS in Glasgow.
    Can anybody tell me what the size of the screen is whilst in packaging as I would like to transport it home in my car.
    Save a few quid in transportation cost (as I will be there anyway - season ticket holder at Ibrox)
    Can it be transported in the "flat" position or should it be moved in the "as it will be in my living room" position.
  2. Billyfergus
    Billyfergus
    Another question -
    Is it possible to put a newer version of the firmware in the screen?
    If so then where can it be downloaded?
  3. Ollem
    Ollem
    Dec 30, 2004
    15
    The box is rather large. The screen itself is about 120x75 cm. I can't rember if you should not tarnsport it flat. I think you should try to avoid that. I was able to put it upright in the back of my car, but the shop I bought it at, told me that often people put it at the backseats of a car without the box. Take a blanket or sleepingback for additional protection.
