LG RZ-42PX11 to PC ?
Discussion in 'LG TVs Forum' started by tabs, Apr 16, 2005.
  1. tabs
    tabs
    Apr 3, 2005
    1,974
    warks
    +129
    is it easy'ish to connect the 2 ? also which connection do i connect the PC to on the LG ? thanks
  2. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Isn't it the same cable that you would normally use to connect a monitor to a PC ?
  3. hugetv
    hugetv
    Tabs.
    The PX11 has both Dsub(standard vga cable type) and DVI inputs.
    You can use either.....just plug in whichever your PC has.
    thanks
  4. tabs
    tabs
    Apr 3, 2005
    1,974
    warks
    +129
    cheers hugetv, i have a DVI on my graphics card, so all i do then is connect the 2 together ? does it take much tweeking to get it up and running, thanks
  5. stewd
    stewd
    No tweaking required on either, the computer thinks the plasma screen is a big monitor.....more importantly we need Sky + codes for this great screen..
  6. Enquirer
    Enquirer
    I'm trying for you stewd?!
    have you posted the list on the other AV forum for me?
    Regards KWIZ
