LG RZ-42PX11 Secret Menu
Discussion in 'LG TVs Forum' started by garymk97, Jan 20, 2008.
  1. garymk97
    garymk97
    Hi all
    looked through a few threads and tried searching but to no avail...there are several mentions of a secret menu but no clues as how to get to it can anybody help...also had no replies on the problem with the tele????:lease:Help
  2. KjK
    KjK
    May 22, 2005
    274
    Pomgolia
    +16
    Your model I think was the one before mine, if its the same then you hold down both menu buttons on the remote & TV for about 10-15 secs.
    That should bring up the service menu
    Hope that helps
  3. garymk97
    garymk97
    Thanks a lot ill give it a look any info on the black band thats running down the screen???
  4. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
    A black band running down the screen:eek:
    No amount of tweaking in secret service menus will cure that
    regards
  5. garymk97
    garymk97
    THanks for the replies ....the problem has got worse, there are now two bands down the screen and the pic is split into three?????just got a reply from LGUK who say theres seems to be a problem with your unit (slight understatement) and get in touch with a qualified technician out there!!! I guess what i need to do now is work out, based on what ive read on here is whwether or not its worth spending £500 to have it fixed??/
